i burnt svcd on cd-r, but it want to burn them on a dvd. will i need to converted them? the files are in bin/cue format.
You must convert if you want a compliant dvd. You can though make a "dvd-svcd" using for example svcd2dvd or dvd-lab, https://www.videohelp.com/guides.php?guideid=727&howtoselect=3;29#727 , no video converting but the dvd may not work on all dvd players.
and please try use the search... http://www.google.com/search?hl=en&ie=ISO-8859-1&domains=www.videohelp.com&as_qdr=all&....videohelp.com
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 10:17
