...please move if it doesn't.
Have one VCD movie split on two CD discs. Using Nero, how do I merge the two onto one DVD-R?
I don't think you can, look here:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=VCD+to+DVD&h...or+List+Guides -
What about some kind of DVD Shrink, DVD Decrypter combo thingy?Originally Posted by Bodyslide
no dvd shrink or dvd decrypter. use isobuster or vcdgear and tmpgenc dvd author, read the guides.
yes Bodyslide
I won't let you down, rob
https://www.videohelp.com/forum/viewtopic.php?t=233348
https://www.videohelp.com/forum/viewtopic.php?t=129786
Between the two of those, you should be sweet
If in doubt, Google it. -
Looks good. Thanks Jim. Question. What about transfering files to my hard drive and then burning onto a DVD. Would that work?Originally Posted by jimmalenko
That's essentially what those guides tell you to do - extract the MPEG out of the VCD using VCDGear or ISOBuster (which is like copying the file to your hard drive, but it strips out all the VCD stuff out of the file). Then you need to resample the audio to 48Khz, and luckily TDA and a few other programs do that for you without you having to do it yourself.Originally Posted by robnytIf in doubt, Google it.
Not sure if it belongs here but need some advice on PAL/NTSC conversion
By HmNtr in forum DVD RippingReplies: 16Last Post: 29th Aug 2010, 11:48
