1) Reading a DVD-ROM
2) Ripping
3) Writing (and does going at higher speeds wear on the drive more)
My Pioneer 108 is my only DVD drive on my PC, so I use it for all of the above. I was wondering what process makes my drive work the hardest. I rip at 8-9x and usually burn 8-12x.
Wear implies moving parts. Spindle bearings and head seek.
The drive is supposed to handle speeds within its rated specs, but one would assume fastest spindle speeds and whipping the heads around on a fragmented disc would give the drive the greatest workout.
Best way to destroy a drive is to place a label off center. Similar to a washing machine with the heavy towels all on one side. -
Just use it, if it breaks in warranty, get it fixed.
And lower the speed on rental DVD playback if you are worried. -
The reason I ask is that my previous drive, Optorite, crapped out on me in only 3 months. I only burned 120 movies or so.
I'm hoping this one will last longer. I average about 5 movies ripped and burned a week -
You didn't ask, but adding a DVD ROM unit would reduce the 'wear' considerably, if you have the room to install it. And the P108 is a much better unit that than the Optowrite, IMO. You shouldn't worry too much.
I wish, but I have an old HP and they only gave me one drive bay. I don't wanna go external yet.
Reading/Ripping (same thing)
Xbox 360 1080p MP4 Playback Issue - Video Flicker/Tear
By kfrye89 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jun 2011, 18:35 -
What do you wear on your head?
By johns0 in forum PollsReplies: 15Last Post: 11th Feb 2010, 20:12 -
Tear artifacts show in my video as the camera moves around, any help?
By bojadada in forum Video Streaming DownloadingReplies: 8Last Post: 23rd Jan 2010, 11:40 -
When I convert a DVD to a 3gp it puts it into spanish
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2008, 16:54 -
Help Me Out by voting for my design so you can wear a new t-shirt!
By ir0n_ma1den in forum Off topicReplies: 0Last Post: 11th Jun 2008, 14:48
