I burn MPG or AVI to DVD (Nero). The resulting DVD is playably on most BUT NOT ALL players! Why? For some Toshibas I can't get anything to work. -R, +R different media - slower speeds (2x) none of it works. INCORRECT MEDIA is often the error message.
What do I need to do to get a DVD they can play?
Pro burns (rented DVD) always play. What are the pros doing that the rest of us need to know about?
Results 1 to 9 of 9
Don't know right now I'll have to find out the models - But what I hear you saying that some commercial DVD players won't play DVD's ? What am I missing
Some players won't play BURNED dvd's.
The ones you get at blockbuster are pressed, not burned.Cheers, Jim
My DVDLab Guides -
Whoa dude! That's a revelation to me!
I didn't know that.
Where to I get a press?
Sounds like Corporate sensorship - control
OK - Is there anyway around this?
Thanks -
Whoa dude! You might want to dial the paranoia back a little.Originally Posted by PHred42
As reboot said, there are two kinds of DVDs: pressed and burned. Pressed ones are made by etching a master into glass, then pressing it into semi-liquid plastic, then aluminizing the surface. then sandwitching the surface under another plastic layer. You are talking tens of thousands of $$ for equipment. But the DVDs will play in everything. You don't use this technology unless you are doing at least several hundred copies.
For less than $100 you get a burner. Those DVDs will play in almost all current players, but understand that this technology has advanced very quickly in the past several years. A DVD player from 3+ years ago might not have the firmware to play burned DVDs. My first player is a nice Toshiba -- great with pressed, doesn't recognize burned at all. But Toshiba never said it would. I'v also got a cheap $40 Chinese player. Handles burned disks fine, but doesn't always handle complex multi-audio-stream situations properly. Oh, well. -
Thanks guys -
This is all new and great info to me.
The 4 players (friends) that don't play my burned DVD are all TOSHIBA.
Thanks again -
Toshiba players, older ones especially, often cannot play burned discs. That's the simple answer, go buy a $30 POS and it will play the discs fine. Almost all newer players will play them fine actually, regardless of brand.
When you decide to buy a new player, check it out in the DVD Players list in the buttons to the left. You'll see what other people's experiences with each model have been.
Subtitles - progressive sync and incompatibility (srt and sup)
By sooojaded in forum SubtitleReplies: 3Last Post: 7th Feb 2012, 15:59 -
An MP4 with some incompatibility issues
By danielbb in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jan 2010, 20:22 -
Windows Media Video DRM incompatibility w/ NVidia cards using TV out?
By Bix in forum ComputerReplies: 10Last Post: 18th Sep 2008, 19:36 -
disc incompatibility seg 3000
By bryanmansfield in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Mar 2008, 14:32 -
Encore/Video Wizard incompatibility with high bitrates?
By moxiecat in forum EditingReplies: 2Last Post: 20th Sep 2007, 15:29
