Anyone try this ... I did a search to make sure this hasn't been mentioned before... it is beta and craps out on occassion. But nic e..
http://www.accuradio.com
Server Too Busy
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Server Too Busy
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): Server Too Busy]
System.Web.HttpRuntime.RejectRequestInternal(HttpW orkerRequest wr) +148
Version Information: Microsoft .NET Framework Version:1.1.4322.2032; ASP.NET Version:1.1.4322.2032"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
We are temporarily experiencing "Server too busy" problems on some channels. However, we believe "Piano Jazz" and "Brit Rock" are fine -- and all channels should be working again shortly. Thanks for your patience!
Cheers, Jim
My DVDLab Guides
