    May 2004
    Saskatchewan Canada
    What is everyones view on this card?
    Is it good for capturing off of satellite dish?
    May 2003
    Peterborough, England
    It won't capture anything off a satellite dish. It is probably fine for capture from a satellite receiver, but not a dish on it's own. For that you need a DVB-S card.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    ATI TV Wonder Pro
    All it does is tune over the air VHF/UHF standard channels, + analog cable channels in the same way a TV set does.
    It also has a S-Video input that you can connect to a cable box or satellite box to get the rest of the channels.
    May 2004
    Saskatchewan Canada
    Thats what I meant... a receiver. I have a DVR510 and want to transfer the video across. I will tape it then play it back and record it. That would work right?
  5. Member edDV's Avatar
    Mar 2004
    S-Video out of the DVR510 to ATI card.
    Audio out to Audio card Line in
    May 2004
    Saskatchewan Canada
    Would I have to get a optical soundcard or can I use my SB Audigy 2 with line in?
  7. Member edDV's Avatar
    Mar 2004
    Any line in, consult the ATI and Audigy docs for configuration.
    May 2004
    Saskatchewan Canada
    Thanks for your help
