  1. hi,
    i recently read the posts regarding resident evil apocalypse and the dummy files that are used to protect the disc,i followed the advice and got hold of the the new dvd decrypter 3.5.2.0
    this worked ok,but now im stuck with a 7.29 gig folder on my HD,ive tried shrink but it gives an error cant find VTS_01_5.VOB.
    this file does not exist in the folder so i presume its a dummy file made by decrypter.
    any help much appreciated.
    jonx
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    use VOB BLANKER to rip those movies then use DVD SHRINK. this has been discussed in other threads for those movies. use the search function.
    Apr 2003
    Maryland
    For these movies, the only thing that has worked for me is to have the latest AnyDVD running in thebackground and then you should be able to use DVDShring in the normal manner. Others have used the latest DVDdecrypter and VOB Blanker but I have not had success with the last two.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
