  1. Hi all, I got an EPSON 200 printer for printing & making backups of my DVD (with New front) covers Well, it's all great & stuff when I can actually find some downloads that'll have the "round cd-dvd" fronts of the cd & dvd's I want to print right.. OK now?
    But, I can't always find them in (cd/dvd) round shaped form. (BOX Only mostly) Now I don't have a scanner also, so im screwed there from making scans., plus, I've also played around with PS7 & the Print CD/DVD ware from my printer to try & make the "DVD BOX PIC only" work & try & fit it into the round shape for my dvd fronts... but to bo luck ,, all parts & wording can't be fit correct to look right.
    Anyway, theres got to be an easier way to to do this, does anybody have any suggestions on this issue? Thanks.
  2. Member p_l's Avatar
    Montreal, Canada
    Yes, click here.
    Apr 2003
    Maryland
    If you mean printing curved text, R200's Print CD program allows you to do that and more.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  4. plenty of pretty round pictures here-
    http://daprogger.mine.nu/
    http://www.customcdlabels.com/
    http://www.cdcovers.cc/
    sizing here-
    https://www.videohelp.com/forum/viewtopic.php?t=253367
    also, insert image as a picture, not as a background, then stretch out to proper diameter to line up with template
    you're welcome
  5. Here are instructions for making the disc templates I use in jasc Paint Shop Pro. I based it upon a Photoshop template I saw on the web somewhere. Techniques are probably similar for other graphics programs.
  6. or like mentioned above, you can just download the templates from the sticky. If your media isn't listed, just make a post their and I'll add it to the list
    Originally Posted by jagabo
  7. Cool , thanks for all the help guys. I really like the PS7 template way, im going to try & get the image into one & see if i can get it all in there. (i've been away from PS7 for a few yrs now) .. ==(
    I just hate how some DVD BOX types will have so much PIC & writing all over in different spots. =(
    Humm, I also might need to actually custom cut & move around certain parts just to get it all to my like. But what the hell... I'll start out with one of my hardest ones & just see. And Thanks again all.. :=)
  8. Originally Posted by Pudah
    Man im sorry, I use Photoshop 7.. I think I have Paint Shop Pro somewhere , I'll have to do some hunting.
