I bought a ati aiw 9600xt video card and the television sound is out of sync. I didn't mess with the video card settings much because I just installed it last night, but I am planning on buying a new sound card to eliminate any issues from my internal sound card. Walmart has a Soundblaster Live LS 5.1 for $28.72. Newegg had a couple of Soundblaster card Live 5.1 cards for 29.99 but they weren't LS. Would there be a noticable between the cards.
Luxury Sedan
Your miserable life is not worth the reversal of a Custer decision. -
ME! ME! LS!
I don't know.Want my help? Ask here! (not via PM!)
Creative doesn't know what it means either.
This is a reply they emailed me.
"The Live 5.1 LS may be an OEM version of the Live! 5.1.
Unfortunately we do not have any information on the Live 5.1 LS. You
may
want to contact Walmart for the specifications."
I put the box covers side by side on the Internet and noticed the the LS says "the standard in 5.1 digital surround" and the Non LS version says "COMPLETE 5.1 digital audio solution." The Non LS also says dolby digital on the box which the LS doesn't. -
Lousy Sound.
But I'm not sure why they don't put that on all their soundcards. -
well its LS
versus NX
or ZS series..common you sound guys!!
What s it all about?
8.1 decoding?
LS Lousy Speakers?
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Dec 2010, 00:25 -
Creative SB Soundblaster Live and Ubuntu 8.04
By Ogilvy in forum LinuxReplies: 6Last Post: 12th Jul 2010, 08:50 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 22:45 -
No soundblaster midi with x-fi extreme audio pci-e
By johns0 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 21:01
