i've been having LOTs of noise ever since i started capturing with my ati rage fury pro... is this the reason why?? ^^;;
this is captured with NOthing plugged into the card...
it's like.... the noise is built into the card or something... -.-;;
is anyone else having this problem? is there a way of getting rid of it?? eesh~!!
video can be downloaded from here....
(right click + save as)
http://us.f1.yahoofs.com/users/c6f807f7/bc/My+Documents/noise.mpg?bcKAXY8ABpdCnfyG
<font size=-1>[ This Message was edited by: Saemin on 2001-12-07 11:13:33 ]</font>
Saemin,
we all get "Permission Denied" message.
You need to go to your "Edit Settings" and change
option to "Public" -
yeah, if u click on the link directly, they won't let you get the file... >_<
try right clicking, then save target as, and you'll be able to download... (i hope!) ^^;
btw, i pretty much get those noise lines on All my caps.. T_T -
I see the same thing with my Radeon VIVO but only when I bring up the capture window with no input. The lines don't appear when I have an active source on the inputs and I don't see any evidence that it is affecting the quality of my captures. Can you see the lines when you are actualy capping video and do they appear in the recorded video?
oh, really??
yeah, i see'em.. but only slightly...
actually, that's not the only noise i get....
when i capture, i get a LOT of... "pixel" noise??? even from cable...
like.. when i watch it, it feels like i'm looking through a ... pixelated glass? hehe.
help!! is it my card?? -.-;; -
Saemin,
If it really IS your card, then you need to bring it back for an exchange.
Else, if you bought it months ago, and am only just starting to use it,
well, you're out of luck!
But, I suspect you have something else going on in your driver/connection
issue.
This may be a driver issue in your case, IF you are NOT seeing ANY video
in your window. Are you getting ANY video? or just this black screen with
white bar at top?
And, of course, you pluged your vcr/hvs/dvd/cable output line to your
Fury's (yellow) Video in (at top of card) ???. . .
and selected the Video source in your Video in's settings, . . .usually
there a ( ) with an image, and every time you click it, it changes to
something different according to your Video source, ie, SVideo/Composite/
or TV
Try above, and if all else fails, you need to also re-check your driver
and Direct X version/installation settup. Keep installing till you have the
proper order of intallation nailed!
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
noise
By smartel in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 14:54 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Where does this noise come from?
By Abas-Avara in forum RestorationReplies: 18Last Post: 28th Aug 2009, 09:40 -
So much noise/distortion :(
By Lee82 in forum Capturing and VCRReplies: 1Last Post: 23rd Aug 2007, 01:14
