Ok, I have two part questions:
1. I have an avi movies and I used The Filmmachine to convert it to DVD. When it was done, the color was all wrong. I mean everything else looks fine but human skin looks light blue....more like dead people.
Does anybody know why? how do you make such correction to look as normal people?
2. I tried to browse this site for how to convert vcd to avi and I can't find any information. My question is, is there such software?
You might ask why convert to avi? my answer is I want to convert it to DVD, but I can't.
I find it easier to join AVI and convert it to DVD than from VCD to DVD.
In other words, I have software that can convert from AVI to DVD but I do not have software that convert from VCD to dvd. Therefore, if I can convert it to avi then I can go from there ( I think?).
Cany anybody help me here? thanks for whatever you can help me with.
-KH
1. Sounds like a codec problem, check the avi with Gspot and make sure you have the codec installed.
2. "Converting" a VCD to DVD is relatively simple. The video is DVD compliant so all you do is extract the mpeg then use a program like TMPGEnc DVD Author. It will create your menus and it will automatically resample the audio to DVD standard 48 KHz. Guide here. You should be able to fit 5 on a DVD.
Don't re-encode if you want to maintain quality. VCD > AVI > DVD is encoding twice, double the loss.
Edit: If you need to join any clips then you can do that within the authoring program by putting the clips onto the same track."Art is making something out of nothing and selling it." - Frank Zappa -
I agree the color being off is probably a codec problem. If the original AVI is off in color, you can use Virtualdub with a HSV or red/green/blue filter to correct it.
tsmuxer makes my subs green
By maca in forum Authoring (Blu-ray)Replies: 2Last Post: 15th Jan 2012, 15:58 -
converted AVI to DVD, VIDEO_TS is created, but once on DVD, movie is green
By jens.3 in forum ffmpegX general discussionReplies: 3Last Post: 18th Dec 2009, 01:43 -
The FilmMachine problems
By olson311dude in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 05:58 -
The FilmMachine v1.6.0.6 Beta is out
By louv68 in forum Latest Video NewsReplies: 0Last Post: 9th Aug 2007, 16:12 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
