Closed Thread
  1. i searched this whole site as well as google and seem to find the answer to this... why, when i load a KVCD template in TMPGENC, does it have no audio? can some direct me to a guide which explains how to make a KVCD using tmpgenc... and, again, i searched, but nuttin... thanx.
    Go to the KVCD site.
    If you ask me, those templates suck anyway.
    Smart encoding techniques are all you need,
    not templates handed to you.
  3. Member vhelp's Avatar
    Mar 2001
    New York
    In short ...
    The reason is simple. Because the template was ment for NO AUDIO
    (video-only) encoding. Not audio. You are suppose to handle the
    audio on your own. This template is mainly for those already
    experience in the kvcd and want a video-only encode.
    If you *still* want to use this template, then you probably have
    to unlock it (if it is locked) and just tic the Video+Audio option
    in the main screen of TMPG. Then, you go to the audio tab and
    select the audio bitrate you want to use
    -vhelp 3110
  4. @buzzinhornets,
    I'll add a little comment to complement vhelp's answer.
    It's a fact that tmpgenc's internal audio encoder is a very poor encoder, and that's why the audio is disabled in the templates. That's common knowledge at the kvcd.net forums.
    So learn to use either BeSweet or HeadAC3he, and you'll get wonderful audio results.
    @lordsmurf,
    Now why couldn't you just answer like that?
    I guess you have some personal vendetta against KVCD?, as all the posts I see from you are pretty rubbish against all KVDC related issues and questions.
    Or maybe it's just that you're a little short on knowledge?, and you can't even answer a simple question like the one buzzinhornets asked?
  5. thanx guys... (except for Smurfy McA$$hole).
