I have the 1016im. I think it's crap compared to my Pioneer.Originally Posted by lordsmurf![]()
Results 31 to 38 of 38
Originally Posted by stiltman
Same story here.
Pioneer is better than BTC by a bit.Want my help? Ask here! (not via PM!)
Bitsetting is one of those "nerd" things too.
Use a DVD-R and you don't have to jack around with that Bitsetting crap. -
lordsmurf wrote
I try to give advice to the "common person". The layman. My people.I'm not blue, I'm tanned!
It would be great if you did not give misleading information on the PIONEER 109 drive with regard to using the latest version of NERO BURN. Because others do not have any problems with using the latest version of NERO BURN with the 109 drive. I find it misleading to give information to others when you fail to mention that others don't have any problems with using NERO 6 & the 109 drive.
Bitsetting is one of those "nerd" things too.Now I call that nerdy because apparently you did not want to go any further with that thread.
now back to this thread......get a BENQ 1620 drive and if you have any questions or problems check out the BENQ 1620 FORUM at cdfreaks.com. remember that a forum is mostly used by people when they have problems with their computer hardware or software......every freaking manufacturer of dvd burners will have their pros and cons.....there are many variables in dvd authoring and burning....there is no best brand to purchase....buy what you can afford that will fit your needs.....my 2 cents... -
Read my other thread about Nero 6 and the Pioneer 109.
Nothing is misleading. You just misread it.
https://www.videohelp.com/forum/viewtopic.php?t=257576Want my help? Ask here! (not via PM!)
Originally Posted by lordsmurfI think,therefore i am a hamster.
Bitsetting is one of those "nerd" things too. It's not often needed. Usually if the DVD player does not see DVD+R, it failed because of the hardware. Magically changing the booktype rarely helps.
PI/PO testings ... also a "nerd" thing. Nobody really messes with that. Most people want to burn a disc, and then watch it. If you want to scan it, run a surface test to be sure the burn is good. You don't need PI/PO or speed read tests as Joe Q. Consumer. Even Joe Q. Experienced rarely cares.
The BENQ drive was not the fault of the system. Other burners worked great in it. The BENQ was just a piece of junk. A survey of 90 people is NOT an acceptable sample for a poll, NOR is a site like that (one concerned MOSTLY with scanning tools) an appropriate polling location.
You sound like the kind of person that buys a car based on how well the floormats fit in, or the shade of window tint. Totally ignoring gas mileage, warranty, engine size, upkeep costs, etc.
I try to give advice to the "common person". The layman. My people. We are not concerned with the "nerd niche" when it comes to technology. It just needs to work, and decently at that. Obscure frills do not matter. -
hey brett,
not sure if you are still checking this thread. thought i'd update ya on my end.
had a disappointing encounter with that vendor (pcontime.net). shipped it WAY late even though i paid extra for "ship tomorrow" option.
got the drive and started playing with it immediately. after about the 4th burn, the drive died. just went down. after reading quite a bit out there in the great wide, i noticed that there are quite a few incidents of bad drives from benq, and that there are certain "batches" of drives that are just not working.
sent it back RMA and got my money back. although they credited my card immediately, there is absolutely NO communcation from that particular vendor. i had to wait until my cc statement hit my mailbox.
so i just ordered an NEC from newegg which will hopefully fare better.
hoping that you're doing better than i.
Advice needed for 1st time HTPC
By hanugro in forum Media Center PC / MediaCentersReplies: 19Last Post: 17th Mar 2012, 12:07 -
My very 1st HDV burn to dvd/need advice please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 16th Jul 2010, 00:51 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33 -
Need advice on buying 1st LCD TV
By majax79 in forum Off topicReplies: 12Last Post: 5th Nov 2007, 11:22 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 21:48
