You missed my point, wild video can be captured to a 10 bit card with black set high, say digital 128 and white low, say 768 to capture the analog overshoots and still have 640 quantization levels in the 0-100 IRE range. This gives digital AGC filters lots of room to work. This assumes the analog input will accept overdriven video (e.g. 1.5v).Originally Posted by davideck
I agree just quantizing the existing image finer will not help, that wasn't what I was saying.
Results 31 to 38 of 38
Originally Posted by davideckYour point here is that analog video needs be adjusted for levels before analog to digital conversion, which is exactly what I am saying. I'm not sure how the PVR-250 works, but if the Pinnacle DV-500 works like the other DV or DC series card, the "Video Input" controls operate on the analog portion of the DV-500 ahead of the A/D so they are doing the same thing in concept as your manual TBC controls. The only difference is they are under computer control and can be remembered in preferences.Originally Posted by davideck
The clamping/AGC issue may be operative depending on how the particular card works. I've used the DV-1000 and DC30plus cards in loop-through mode and the controls operate just as you would expect. Clamping will lock back porch of blanking to 0 IRE. Video can go up or down from there. I do agree that AGC has to be turned off before you have manual control.
If for some reason these controls do not work at all on the DV-500, then an upstream level setting device such as a proc amp or TBC with proc amp controls will need to be used so that white and black levels can be set. As a poor man's alternative, many S-VHS VCR's (higher end ones) allow manual video gain control while in E-E mode. If you have access to one you could try that as a poor man's proc amp. -
Are you saying the controls did nothing or that you couldn't find the right settings formula for that image?Originally Posted by amira
If the controls aren't working call pinnacle about it. -
I'm saying even when I found the controls and move the sliders, it didn't help the video image look better.
I sent Pinnacle an email about it a day ago but still no reply.
I'm going to start experimenting this weekend. And get back to you. -
Pinnacle support -- thats an oxymoron
I remember the Miro-Pinnacle days.
Everything had to be tweaked just so.
Miro was a German company that was acquired by Pinnacle.
Their cards were good in their day. I found calling Germany got better results than the local Pinnacle guys.
The DV-500 was one of the last "Video for Windows" cards. Rather old school but worked if you could trust the drivers. It was all about drivers back then.
This review takes me back to what it was like back in Y2K. IEEE-1394 was new ($3000 VX-1000 camcorders) and required proprietary drivers (before DirectX support). Hard drives were ATA33 and almost fast enough for DV but not quite fast enough for MJPeg analog capture. RAID was needed. Everything was about getting drivers to work.
http://www.tvtechnology.com/reviews/features/pr-Pinnacle-DV500.shtml -
I had a Pinnacle NitroExpress card/system if you remember those ... mega bucks in its day -- pain in the butt any day .
I am having the very same problem. "Under the sun" bright captured areas are washed out and brighteness/contrast controls do not help. See my old post : https://www.videohelp.com/forum/viewtopic.php?t=250004&highlight=
Did not manage to solve it Im afraidKONX OM PANX
tsMuxer for Snow Leopard
By jangai in forum MacReplies: 16Last Post: 22nd Dec 2012, 19:09 -
Baltimore Snow pics
By zzyzzx in forum Off topicReplies: 11Last Post: 22nd Dec 2009, 23:56 -
10.6 Snow Leopard compatibility
By 303 in forum ffmpegX general discussionReplies: 5Last Post: 15th Nov 2009, 10:10 -
ffmpegX and Snow Leopard
By drasw in forum ffmpegX general discussionReplies: 17Last Post: 8th Nov 2009, 11:09 -
pink snow from dvp3960
By warr in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Nov 2007, 14:11
