here we go ive been away shall we say for a while & basically would like some decent feedback on the pioneer 109
any 1 come on ive had a look around and there seems to be
plenty of people like them are they worthy of my dupes
lingy
ps thanks in advance
Results 1 to 11 of 11
Put this in your pipe & smoke it:
https://www.videohelp.com/forum/viewtopic.php?t=254224&highlight=first+impressionsIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
wow u got 649 pposts i been here longer got 60 hehehe
depends what ur smoking m8
so you think the 108 is better
thats what i was thinking
cheers for the speedy reply
lingy
I didn't say that. I wouldn't know, as I own neither. I was just giving you a link with (hopefully) some useful feedback. IMO, Pioneer is a quality drive, regardless the model #.Originally Posted by lingy
George Carlin -
you can find the new firmware for pioneer a-09 at http://forum.rpc1.org/portal.php this page has all the firmware for any players....
Bought the DVR-A09 2 weeks ago. Own several other brands but this was the first Pioneer drive. Out of the box with no firmware update, burning TDK 8x (Japan) at 12x and Sony 8x at 8x. Twenty - six burns so far, with no coasters using Shrink, Nero 6, Sony DVD Architect. Rock solid. Will not nor do I ever recommend updating firmware unless you are having problems or can be assured you will gain something. Stick with good media and you should not have problems. What has worked for me may not work with others. I consider this drive the A09 equal to my Plextor 716A. Pleased with the product, so far.
I consider the 108 a better burner now as I have 8 speed discs that the 109 only burns at 4 speed and the 107 and 108 will burn them at 8 speed Also the -r I have tried don't work in a Xbox so here I am with a newer and slower and incompatable drive and the two older models are better at least until a descent firmware comes out Pioneer has taken a step backward this time.
Some people think the 105 was better than either the 108 and 109. I happen to support NEC after being a loyal Pioneer user. Either one is going to serve you well as long as you stick to good media. If I had a 109, I would keep it.
Still a few bugs in the system... -
You really should check out the CDFREAKS forum, the PIONEER one to be precise. Lots of good 109 information there.
This is a nice drive.
http://club.cdfreaks.com/forumdisplay.php?f=87Want my help? Ask here! (not via PM!)
multiAVCHD - (RT) Invalid array index. Array is empty - Line 109.
By JackyWang in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Oct 2011, 09:53 -
NeoDivX 2008 3002.0.1.109
By zebbra in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2008, 23:20 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 05:44 -
VideoInspector updated to v1.10.2.109
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 20th May 2007, 15:03 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 09:48
