i am looking for the best possible resolution for capturing mpegs between 2 hours and 30 mins and 3 hour movies
i tried creating a 2 hour and 30 minute movie but the bit rate calculator spits out the wrong bit rate and i get a message from tmpegenc dvd author stating the file maybe to big to fit on a 4.7 dvdr.
the resolution i am capturing in is 720x480 for my movies.
would it be best to capture in 352x480 and choose the highest possible bitrate for a 3 hour movie or 2 hour and 30 minute movie??
please help i am use to capturing 2 hour movies at 720x480 but anything beyond that limit i get artifacts and errors please help!!
From this Bitrate Calculator, assuming 224kbps audio:
2.5 hours = 3837kbps
3 hours = 3159kbps
If you're looking at only doing a quick n dirty transfer and dump to DVD with minimal to no editing or filtering, I'd go with 352 X 480 @ 3700kbps for 2.5 hours and 3000kbps for 3 hours. This "buffer" below the calculated bitrates then leaves you room for a decent menu, and means that you're not at the bleeding edge of the media.If in doubt, Google it. -
352x480
Whats considered HD/Blueray resolution?
By shagratt71 in forum Newbie / General discussionsReplies: 12Last Post: 11th Jan 2012, 07:13 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Whats the best resolution for a 32" Monitor/TV
By adamf154 in forum ComputerReplies: 7Last Post: 6th Jul 2010, 09:57 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57 -
whats the best way to export my home movies from premiere elements 4
By simoupnorth in forum Video ConversionReplies: 0Last Post: 4th Jan 2008, 16:38
