Hi I have tried a few times to burn both shrek and shrek 2 with no sucess useing dvd shrink and nero 6,dies any 1 no of any reason why this would be?is there some sort of protection on these titles?if so how can I burn them?THX
Results 1 to 14 of 14
Have you tried to upgrade Nero to the newest version?
No, What version is the newest as I thought I had it??also I think i am running at bare minimum specs for all this stuff to work my mate told me that i couldnt install a dvd writer on my pc but I tried it and it worked all of the 20 odd other discs I have ripped worked fine up till now hmmm???
Hi I also had probs with Shrek and DVD Shrink tried to back up
before kids made a coaster of it.
Got stuck in loop showing dragon flying out of clouds would
show a few seconds of this then would repeat got a dvd full of this
loop
Rabg. -
On the shrek 2 dvd there are 2 separate movies with slightly different endings. You need to use shrink in reauthor mode to just select one of the movies.
So ur saying that I cant do a full copy of shrek 2???cause I would like the whole lot if possible.
You can, although the compression might be too high. Many people just do movie only backups, in which case you would have to pick just one ending. If you have DVD Decrypter, use it to burn from Shrink, rather than Nero.
Read my blog here.
Thx for all ur input,in the end I just used shrink.re author and one of the movie versions,why is there more than one???
I've never had any problems with nero (all dvd versions) i'm now using nero express and havn't had one coaster yet.
Even with both shreksI could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
Rufus T. Firefly (Groucho Marx) -
Creamygoodness7 - The alternate ending is done using a technique called seamless branching. Usually it is done at the chapter level, with one chapter being the original, and another being the alternate version. When you pick a version from the menu, the correct chapters are played for that version.
When DVD Shrink analyses the structure of the DVD, it sees each version as a seperate film. I have seen DVDs that appear to have more then 15GB of movie on them because of this. When you choose a movie in reauthor mode, you are really choosing which set of chapters to include.Read my blog here.
Having trouble burning a DVD off of my DVR
By RRFeeney in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2009, 15:57 -
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
Burning DVDs trouble
By ssaamm in forum Newbie / General discussionsReplies: 8Last Post: 4th Aug 2009, 06:24 -
Shrek The Third
By boldego in forum DVD RippingReplies: 3Last Post: 13th Nov 2007, 22:10 -
trouble burning DVDs
By nick177th in forum DVD RippingReplies: 9Last Post: 5th Oct 2007, 17:10
