Results 1 to 12 of 12
  1. What is the easiest way to make an EXACT copy of a dvd with the menu and the all the extras, so you cant even tell it was a backup. Also without a dual layered disc. I've seen exact copies of dvd's that were not on dual layered discs. What is the easiest, or most popular way this is done.
    Thanks,
    Dave
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    An Exact copy can't be done on a DVDR without changing the compression. You will need to either backup with compression. Or backup with movie only. Some even put the Movie Only on one DVDR, then do the Extras on a seperate DVDR. Look at using DVDDecrypter and or DVDshrink. Both are free and guides are to the left.
    https://www.videohelp.com/forum/viewtopic.php?t=139869
  3. IF the original is a DVD5, or you have a dual layer burner and disks, use DVDdecrypter, Iso Read, then ISO Write.
    IF the original is a DVD9 and you do not have dual layer burner/disks then it can't be done. You can make it look the same with DVDshrink, (keep menus extras etc) but some compression will be required so it won't actually be an exact copy.
    There are 10 kinds of people in this world. Those that understand binary...
  4. Originally Posted by dlew2222
    The same way you put 4 liters of water into a 2 liter bottle (duh!).
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  5. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    The only way of obtaining an exact copy of a dvd with all extras, menu etc is to split to 2 discs.
    Otherwise, use a dual layer disc, though this route is still expensive.
    many compressed movies on one disc with all extra and menu do sometimes look identical to the original, you cant really tell the difference.
    Maybe you have seen an compressed version, which has turned out to look like an exact copy.
  6. Does Dvd Shrink just compress the entire dvd data, but sacrifice quality? If so, this is a route im still wiling to take.
    Thanks a lot
  7. Does Dvd Shrink just compress the entire dvd data, but sacrifice quality? If so, this is a route im still wiling to take.
    yes, u can do the entire dvd...
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd suggest you try the guides section, and choose DVDShrink as the tool
    If in doubt, Google it.
    Mar 2003
    Kansas City MO
    Exact copy. Buy the DVD. Even the Case and pretty ink on the disc will be the same. Is this what you want?
  10. thanks alot. DVD shrink is very simple and easy to use.
    Thanks,
    Dave
    Aug 2004
    Oshkosh, USA
    Not as simple as DVDShrink, but the quality ends up being far better is the DVDRebuilder route.
    With the built in QuEnc encoder you can't tell the difference, even with a very large DVD9 being re-encoded to DVD5. I have been learning this lately myself, which is why I can tell you, it is not as quick & easy though.
    Oh, there is a 1-Click method, don't get me wrong, that's what I use. But, it takes about 5-10 hours minimum for it to process, depending on your processor speed and what quality options you select (the better the quality, the longer it will take).
    But man, you just can't beat the end result. If you didn't know it was a re-encode, you couldn't tell by looking at it. Leastways, I couldn't. Great program, and freeware only makes it better.
  12. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I'll second that. After using DVD-Rebuilder, I'm a complete convert.
    I do use DVDShrink for speed when there's less than 20% compression needed (or 80%, as shown in Shrink).
