Is there a way to convert AVI files to MPEG 4
Look to the left under Convert. Should be a few guides to help you out. If not do a search in the Forums.
I found this from Google
http://www.esato.com/archive/t.php/t-83182 -
Many are already. Xvid, DivX & cetera is mpeg4 AFAIK...
Perhaps they mean real MPEG4 as in MPEG4 video/audio in an mp4 container?
If your avi file uses XviD, etc. and compatbile audio like aac or mp3 then you can simply remux to mp4. Check out mp4box, you can also have ttext subs. Should point out though that mp4box doesn't support AVC muxing, so if your avi has AVC video you will need to use mp4creator.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
