When the "create titleset" task is running,the progress bar doesn't go further than 99.9%.
But according to the log,the dvd creation completes;because the finalising is done and the dvd folder authoring too
The SVCD2DVD notification pops up also.
When playing the movie,everything seems OK.
This is with RC2...
When the popup pops up then it is done. I shall be refineing the progress bar for RTM
Progress issue
By djw66 in forum ffmpegX general discussionReplies: 2Last Post: 30th Jun 2011, 17:46 -
After splitting and combining with AVIdemux, progress bar goes on after end
By johnharlin in forum EditingReplies: 3Last Post: 21st Oct 2010, 05:40 -
HELP!!! ffmpegx progress zero kb
By smjsinclair in forum ffmpegX general discussionReplies: 6Last Post: 9th Aug 2010, 19:06 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 8th Oct 2008, 00:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29
