  1. Hello All,
    Please am in despirate need of your help, i just convert a DivX.avi movie to Mpeg and when i play it the video quality was good but there was no sound. I have the DivX4.11 codec and i just installed alpha 3.11 and i tried it but still no sound.
    The size of the movie was 1.14gigabit, do i need to cut it or compress it please which should i go for?
    Please your quick responce will be highly appreciated, thank you for your time.
    Instinct7
  2. Have you tried seperating audio from the movie?
    With VirtualDub in Full processing mode go to file -> Save WAV and save audio to a file which you then rename from WAV to MP3. Use DIVx AVi as video source and MP3 file as audio source. I have tried this in TMPGEnc and worked great.
  3. I had the same problem, solution I used? raise your directshow to priority 1 under options-enviromental settings-vfapi plugin. I found 1(+) to be best since anything higher made encoding slower and divx playback wasnt working correctly (artifacting bad)
  4. Hey, i tried to covert a Divx to mpeg, but I had the opposite problem. I have audio, but no video. I used TMPG to convert, and I remember last time I tried converting it played video in the black box during conversion. This time there was no video. What did I do wrong?
    MIke
