    Dec 2003
    The setup:
    Formac Device using Vidi capturing .dv 2 gig files.
    iMovie 5HD
    After importing clips into iMovie 5HD and saving, can I then delete the original clips or does iMove reference them?
    Thanks Wayne.
    If the Thunder don't get you,
    the Lighting will.
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    If it is like other software, the originals files are used. I would'nt delete until you are happy with the final saved project.
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Look under where you are saving your project. If there is a folder with video files exactly like yours, then it should be okay to delete. But in MY experience it only does that when I use iMovie to capture the video, otherwise it still looks for the files.
    So I'd say keep the files just in case until you're done with them.
