I've noticed that Mozilla Firefox doesn't loads about 60% to 75% of the images on pages with a lot of images. If I load the page with IE, with everthing else the same, all the images usually load.
If I hit reload, the some of the images that didn't load will load and others that loaded the first time will not load.
I was getting around 50% before I changed my Ad Blocking setting (under privacy) in Zonealarm from High to Medium. Even before that change I was still getting around 100% in IE.
I got Mozilla Firefox configured to load all images. Any other tweaks or suggestions would be appreciated.
I have the Sun Micro systems java support plug-in ... It puts a coffee cup icon in my system tray whenever it's used ... which isn't that often.
Maybe I do need some other plugin but it appears to be a page loading issue to me.
Again, I'm having problems fully loading pages that contain a large number of images. If I view the same page in IE it usually loads completely. An example of one page that I have trouble fullying loading in Mozilla / Firefox is www.foxnews.com. It's like the page stops loading too soon ... is there some tweak that makes that time longer? -
rkr1958, have you tried loading in a new profile then checking the site? May be a conflict with an extension or something. Also, what version of Firefox are you using? I'm using the 1.0 and have no problems loading foxnews.com
Hope this helps
RogThere are many ways to measure success. You just have to find your own yardstick. -
Are you using the "Tweak Network Settings" extension on "power"? Or something similar to "speed up" Firefox?
Perhaps the problem is that Firefox is trying to load too many images simultaneously and some items are timing out. I get a similar problem with I use the "Tweak Networks Setting" extension on "power" on a dial-up connection.
Regards.Michael Tam
w: Morsels of Evidence -
i had the same problem, just go to tools> options > web features and you will see abox that says load images, keep that box tivked, but the box beloew that that says load images from originating site, untick that, meaning do not put a check in the box, do that then close the browser then opne again and you should be allright..holla back
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Thanks guys.
The latest ... 1.0Originally Posted by burnman99
No, I don't think so. I'm not sure what this is ... I've got broadband, not dialup.Originally Posted by vitualis
I verified that this was had I had my configured also.Originally Posted by SIRCOOKS
I think this is the crux of the problem. I went back, under "about:config" and reset most everything back to the default value. I also tried some tweaks that I read about to speed it up. Last night that seem to help ... the www.foxnews.com page loading went from 75% to around 95%. This morning it's 100%. I do think, when I'm having problems something is timing out. If it gets back enough I can always load the page in IE, but I'm hook on Mozilla / Firefox and as long as I'm getting 90%+ loading I'll stick with it.Originally Posted by vitualis
Thanks again for all the advice.
P.S. I'd seen the Mozilla / Firefox tweaks list here but couldn't remember the post. I did a google and found this http://www.freerepublic.com/focus/f-news/1299854/posts The one difference though was the addition of a new variable "nglayout.initialpaint.delay" (an integer set to 0) which did seem to help. It got me from 75% to 95% last night and 100% this morning.
mozilla is trying to set a one day download record today 6/17 w/firefox 3
By aedipuss in forum ComputerReplies: 27Last Post: 3rd Jul 2008, 10:03 -
Mozilla is becoming *VERY* idiot-friendly :-(
By Midzuki in forum Off topicReplies: 10Last Post: 25th May 2008, 16:12 -
Mozilla Firefox
By maccool111 in forum ComputerReplies: 3Last Post: 7th Apr 2008, 21:31 -
fully hd,hdmi,hd ready
By gunukhan in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Jul 2007, 13:14 -
Internet Explorer and Mozilla Firefox
By kimco52 in forum ComputerReplies: 19Last Post: 10th Jun 2007, 04:06
