I have two corrupted avi file. From GSpot, they look totally fine. Using Windows Media Player, told me it does not support this file format ON HALF WAY. If I use VisualDub to open them, VisualDub will do "reconstructing missing index block", and then fail. I tried VideoFixer and DivFix, they all find index problems. But the original file size is 13.2G and they only spit out a "fixed file" with the size of 0.99G (both applications). Media Player can't play the fixed file from the beginning, which is worse then the original corrupted avi files. Can anyone please help me how to save those avi files? Thanks.
Results 1 to 1 of 1
Trying to fix a .mov that was corrupted after using undelete software
By Elderain in forum Newbie / General discussionsReplies: 10Last Post: 11th Oct 2012, 13:47 -
m2ts file corrupted, how to fix the chain?
By Srivas in forum EditingReplies: 7Last Post: 13th Mar 2011, 11:42 -
I have a corrupted Quicktime MOV file I need to fix.
By Videogamer555 in forum RestorationReplies: 0Last Post: 5th Mar 2011, 01:51 -
Corrupted AVI files after power failure
By Babaloo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2009, 16:58 -
how to fix a corrupted file?
By sharmine in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 18:03
