Results 1 to 17 of 17
    Mar 2002
    Used the RC2 version for 1st time and the multi looks fine except i set it for chapters every 5 mins and none were created other than where the 2nd part of the film starts?
    Worked fine on relases in the past including RC1
  2. I'm having the same probs too, chapters only seem to work reliably when RC2 converts an AVI file itself, hopefully a fix will be available soon.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I need to investigate this, but i need some help. Can someone upload a mpeg where this happens. I.e single mpeg, single VTS, chapters setup but none in the final DVD.
    ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676/Chapter%20Issue/
    Mar 2002
    mine was 6 mpgs to make 3 films on 1 dvd
  5. What is a chapterd? A new term for a really crappy scene?? vbg
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Did the whole DVD not have any chapters? Was it just one VTS or one Title(mpeg)?
    Can you replicate with one mpeg on its own?
    Mar 2002
    The whole dvd didnt have chapters
    i will try and recreate with 1 mpeg tonight when i get home from work
  8. same trouble here with RC2
    is there still a link for RC1 till the prob got solved?
    Thanks for fixing!
    bobbel
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    waiting for an example to resolve this - feel free to help me out.
  10. I get this problem with every mpeg (SVCD) I add to SVCD2DVD.
    Checked this twice with other Chapter-times.
    bobbel
    Mar 2002
    i am uploading a file called creep i checked it and it still did the same created a dvd with menu but no chapters
  12. I've uploaded a Tv episode, plus the log file, it seems to be happening for most mpegs for me too.
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. I have this fixed now. I will upload RC3 shortly. Thanks for the uploads and the assistance in this.
    boggle: As your file has nav packs it is not reporcessed by S2D. Therefore to have it processed properly with RC3 you will need to use the original. Does that make sense?
  14. Any info on what exactly the problem was chrissyboy?
  15. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I thought originally that it was the duration of the files not been retrieved correctly... but it wasn't. (i need to improve that however). It was the VOBU creation, or rather the lack of them... no place to insert the chapter points.
    Mar 2002
    yes makes sense Chris
  17. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    BTW RC 3 is now available... Let me know if you agree that this is fixed.
