I thought I had this beat, but apparently not. I encoded an XVid to a DVD using CCE. My Avisynth script is as follows:
# -= AviSynth v2.0.8.0 script by FitCD v1.2.4 =-
AVISource("input.avi", False)
LanczosResize(640,432,0,3,640,474)
AddBorders(40,24,40,24)
#Trim(0,33307).FadeOut(150)
ConvertToYUY2() # For VirtualDub or CCE
I used DJRumpy's guide for all the CCE settings.
After encoding, I ran it through pulldown.exe to convert the framerate to 29.97 fps. All of pulldown.exe's options are left on default.
For audio, I used VirtualDubMod to extract and converted to ac.3 using besweet.
After authoring with DVDauthorgui, I tried playback with a Mintek DVD-2110, and a Pioneer DV-343. Playback seemed fine on the Mintek, but on the Pioneer, it played about 1 second before it froze.
Anyone got any clues?[/quote]
Pioneer players are notorious for freezing when you use streams created by Besweet (as the streams it creates are not completely Dolby Digital compliant). Personally I use the TMPGENC AC3 encoder, as it is a licensed product and therefore totally compliant. http://www.pegasys-inc.com/en/product/tsp_ac3.html
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Ffmpeggui will transcode audio to AC3 fully DVD compliant, and it's free.
It will only do DD2.0 though.Cheers, Jim
My DVDLab Guides
DVD disk freezes during playback after being finalized
By 1234567 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 13th Apr 2012, 00:00 -
Jerky Playback on DVD Converted from HI8
By Funky Monk in forum Video ConversionReplies: 3Last Post: 15th Apr 2010, 10:19 -
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 22:55 -
NEWBIE - Converted and burned XVID to DVD -- Blurry/boxy on TV
By baldieme in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 18:47 -
DVD recordings HDD to DVD-R freezes during playback
By NiteLite in forum Newbie / General discussionsReplies: 4Last Post: 16th May 2007, 02:51
