  1. I have "Nero 6 Version 6.6.0.5" and I was wondering if I can burn a "Make Super Video CD" onto a DVD disc. I havent tried it yet but I want to know if it would work or it only works on v.6.6.0.6
  2. Yes it will work
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    https://www.videohelp.com/forum/viewtopic.php?t=129786 might have some useful information.
    If in doubt, Google it.
  4. I also forgot to say that I want to burn 3-6 video's to a DVD which I can later play it on a DVD player. Can it be possible to add more then 1 video's and burn them on a dvd?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sure. Enter the total running time of all clips into a bitrate calculator to get the bitrate you'll need to use, then convert each clip in turn using this bitrate. http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might be able to assist you with this.
