  1. Hi
    I`ve happily been using svcd2dvd for maybe a couple of weeks now
    no problems .
    I haven`t changed any settings atall , but now when I encode some mpgs & .avis to dvd they`re always well over allowable size for a comon dvd5
    Ie My latest efforts of 5 files , 2 movies , one movie is 2 .avis
    totalling 1.36 gig`s , next movie is 3 mpg`s totalling 2.15 gig`s , for a total of 3.51 gigs .
    The output was 7.01 gigs . & results were real bad , Ie blocky , on the
    3 mpg files .
    I have done 5 files before totalling this much , or close , & always
    received an output well within range of a standard dvd5 of just over 4 gigs
    I`ve always used full dvd resolution before with no problems , may I need to set to svcd resolution for some reason with these files ?
    have I missed something obvious ? Maybe the diff was a few files were .pal , & needed to be converted to ntsc ?
    Cheers
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is this RC2?
  3. i`m sorry to sound daft
    But what is RC2? & how can I tell if so ?
    Cheers
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    RC2 is the latest release. It has the "Auto Fit" option which sounds as though would help you here.
    Have a look at:
    https://www.videohelp.com/forum/viewtopic.php?t=256534
    FYI: Help->About will tell you the release name.
  5. Wow
    Nice feature...
    Got it ..using it now.....
    PS why do similar sized .avis increase in size so much
    where a similar sized svcd/vcd won`t ? So far in my
    eperience .
    Can I still mix n match .avi`s & svcds/vcds with this
    version/feature as I did with previous version , where I could make
    one dvd from a couple of .avi`s & svcds ?
    Cheers
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    eperience .
    because avi's need to be encoded to mpegs.
    Yes. Just make sure you click "auto fit" b4 you author
  7. Cheers
    Worked great .....
    Fanx m8
