I am trying to run an MPEG2 file through VirtualDubMPEG2 using the MSU deblocking filter to, obviously, reduce blockiness. VirtualDub crashed with an "out of range" error in the MSU deblocking module.
Am I going about this the right way? Is there a way to filter an mpeg2 file in VirtualDubMPEG2? What compression should I use if I want to eventually get back to an MPEG2 file after deblocking?
Thanks.
Are you using version 2 of the MSU deblocking filter? It was just released. Might work better.
You shouldn't save the result at all. Frame serve to your MPEG2 encoder instead. -
I never had this problem with this filter (I use it always with my mpeg 2 DVB sources)
Of course, I frameserve to TMPGenc plus to encode.
MSU_deblocking filter Rules (but it is slow....)La Linea by Osvaldo Cavandoli
H264 in-loop deblocking filter, a good thing?
By deadrats in forum Video ConversionReplies: 1Last Post: 12th Feb 2012, 20:48 -
Creating new MSU VirtualDub filter.
By diablo23q in forum ProgrammingReplies: 5Last Post: 15th May 2011, 15:04 -
How to keep ffdshow post processing(deblocking filter) in finalized video
By Milardo in forum EditingReplies: 6Last Post: 5th Apr 2011, 05:09 -
Help finding an AviSynth deblocking filter that works at high resolutions
By Cman21 in forum EditingReplies: 17Last Post: 9th Nov 2010, 06:30 -
Using MSU Smart Deblocking Filter...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 20:17
