I am getting ready to purchase my very first DVD recorder. After reading trough many forums, I am thinking of buying a Pioneer 320. It records to
-R and -RW. A couple of my buddies have Lite-on's that only record to +R and +RW. My question is, If I borrow finalized +R or +RW DVD's from my buddies, will I be able to view them on my Pioneer 320 since it only records to -R and -RW? Any help or advice will be greatly appreciated.
Thanks.[/b]
Results 1 to 16 of 16
Here is says No.
http://www.dealtime.com/xPF-Pioneer_Pioneer_DVR_320_S_DVD_RECORDER -
Some machines will play discs even though they say they won't. Try taking a DVD+R disc to somewhere they sell the Pioneer and see if it will play.
True...Best to try it, or wait until someone that has one responds.Originally Posted by samijubal
I've played DVD+RW's on my Pioneer DVR-510H-S which has an older Pioneer DVD drive than the 320. I have never tried a DVD+R. In my opinion there should be no problem playing those finalized discs on the DVR-320 just at the Lite-Ons should have no problem playing finalized DVD-R and -RW discs.
I've got a 420, the 320 is the same machine minus the HD, plus a firewire port. It plays DVD+Rs perfectly, and the +R discs I tried were not bitset to DVD-ROM either, so they definitely will play +Rs just fine.
I can get back to you on +RWs if you want me to try it out, but I can't do it now, probably tomorrow I can burn one and try it.
I've the entry level dvr-220 recorder and it works well with DVD+R/RW,
the 320 is the next modell with firewire . -
Thanks for all the helpful info. I beleive this is the DVD recorder I am going to go with. Anyone know of anyplace curently with a good deal on them?
Thanks.
Do you need the firewire port? Otherwise I know Wal-Mart sells the 220, same machine minus the firewire. I think it goes for around $224 or some odd price like that, at least last time I saw it.
I just got the 420 H from Costco and I have had the machine (it's great) for one week. I did not know that I might be able to play +R discs. I am going to try it tonight. If it can play them, can +Rs also be recorded to the HDD? I will try this as well. If anyone has done this, let me know.
E -
Hope I'm not jumping in where I don't belong. If so, please forgive.
I own the Pioneer 420H-s. Love this machine. They'll have to pry it from my cold hands before I'd give it up. An incredible breath of fresh air after the iLO.
I had the iLO HD04 and have an UN-Finalized +R DVD. It will not play in the Pioneer. I also have some FINALIZED DVD+R's and they will play fine.
I also have an UNfinalized DVD+RW that was made with the iLO HD04 and it plays fine on the Pioneer. I don't have time tonight to see if you could do a Backup copy and make it into a DVD-R. But, the iLO menus and functions worked and played fine for me. -
I was also able to play a +R disc (finalized) in the 420H. I have not tried to save it to the HDD. If I have time to do so later today, will try. This is such a great machine...
Evga 8800 gts 320 sli,
By dmx1nc in forum ComputerReplies: 0Last Post: 2nd Jan 2012, 21:02 -
burn blu ray on DVD and read it on Pioneer BDP 320
By Coyotito in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2009, 12:45 -
Dingoo A-320 Handheld Media/Game player!
By Super Warrior in forum Off topicReplies: 5Last Post: 27th Jun 2009, 11:40 -
Matsui 320 Hack
By ironchub67 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 23rd Jun 2007, 10:24 -
I can only capture at 320*240!!
By MisterBubbles in forum Capturing and VCRReplies: 1Last Post: 13th Jun 2007, 22:36
