    Hi
    I have an ac-3 track which is 192kbps. It has two channels, but the source is actually mono so I believe the two tracks are identical. Is there any program that can take one track (at 96kbps) and make a mono ac-3 without re-encoding the file?
    If it has to re-encode I might as well use mp3, but would like to know if it is possible to do it without converting first!
    Thanks for any help
    Nick
    Apr 2004
    Miskatonic U
    No. You don't have two AC3 audio tracks, you have one audio track with 2 channels. To split this will entail reencoding.
    Read my blog here.
    OK thanks. I suppose I should have said channels rather than tracks.
    I'm surprised there is no way of taking one channel out of an ac-3 file and make it a mono ac-3 file without re-encoding it.
    Nevermind!
    Nick
