A friend asked me to transfer some sentimental family videos to DVD. My plan is to run my Panasonic SVHS player to the E20 and record in XP mode (each tape is less than 1hr). Then copy the DVD-R's to hdd and reauthor with menus with DVDLab.
Questions:
1. I have a $50 Sima color corrector. MV is not an issue since it's home video. But do I need to link the Sima between the SVHS VCR and the E20 for any benefit? Or am i better off linking via S-VHS from VCR to E20?
2. Should I be using XP mode or SP. i've read that XP modes can cause DVD-R compatibility issues with certain set top DVD players..
3. Any other suggestions/tips for getting a very good end product??
Thanks..
I tried XP vs SP on the E-20, there was so little difference that I always used SP. If I looked really close the picture was maybe very slightly sharper, so little that I don't think you could see any difference from videotape. I've never used a color corrector, but if the original recordings look good then you should be OK without it. The VHS copies I made on the E-20 are almost identical to the source except cleaner.
I have a Sima SCC and I no longer use it EXCEPT to defeat MV. I think it adds noise to the signal chain and the color correction produces unfavorable results. You may need to experiment with it to suit your own tastes, but in my experience it is just a MV defeater with some added functions and not really a processing amp.
Blazey - sorry to be off-topic, but is your member picture Peter Cushing in one of the Hammer Frankenstein movies? COOL!!
VHS to DVD Help (panasonic dmr-ez48v)
By BrianJ844 in forum Newbie / General discussionsReplies: 14Last Post: 21st Jul 2010, 19:03 -
No video on Panasonic DMR-EZ47V DVD/VHS player
By orangeprs in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2010, 15:42 -
45
By inherindian in forum Newbie / General discussionsReplies: 7Last Post: 4th Mar 2009, 20:26 -
3 questions about VHS > DVD
By Salva Veritate in forum Capturing and VCRReplies: 13Last Post: 26th Jan 2008, 14:05 -
Two newb questions about the DMR ES46V
By Unikfreak in forum DVD & Blu-ray RecordersReplies: 6Last Post: 18th Oct 2007, 02:22
