I have encoded many files in virtualdub without any problems. But now virtualdub has started to crash. After a while the encoding just stops. The video rendering rate drops to 0 fps. When I exit the program after this has happened this error message is shown:
An out-of-bounds memory access (access violation) occurred in module 'xvidvfw'.
I have tried other video compressions and audio compressions and I have tried to re-download virtualdub.
Input file:
Codec: Xvid
Audio: 5.1 AC3
Picture size: 640 x 256
Out file:
Codec: Divx 5
Audio: MP3 128kbits/s 48000hz
Textsub video filter added
Thanks in advance!
Results 1 to 12 of 12
If this is happening on one particular file, and always at the same place, you probably have a corrupt source.
You can try DivFix but I doubt it will help.
https://www.videohelp.com/tools?tool=DivFix
If you can figure out where the bad frame is you can trim in VirtuaDub to avoid the bad section. Save in two parts. -
mpeg - what? 1 or 2? For mpeg2, you need VirtualDubMod.
/Mats -
I have Downloaded virtualdubmod and tried to open the mpeg but then I get this error:
"MPEG Inport Filter: Pack synchronization error"
Do I need any plug-ins or something??
The File is mpeg-2 -
No plugin needed. Seems you mpg is somehow broken. Try a fast remultiplex with TMPGEnc
/Mats -
1) Streams -> Stream ListOriginally Posted by ghozt
2) Right click on the stream you want select items from menu. -
In VirtualDub (not mod) just change audio to "Full processing mode", set codec under "Compression..."
In mod, there's something under stream list I think.
/Mats
ColorTools 1.4 crashes Virtualdub
By LSchafroth in forum RestorationReplies: 10Last Post: 26th Apr 2013, 09:28 -
VirtualDub crashes when using MSU Subtitle Remover :(
By ralf07 in forum SubtitleReplies: 1Last Post: 17th Mar 2012, 03:16 -
Olympus camera memory card crashes virtualdub
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2011, 01:08 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Virtualdub crashes
By Kevlin in forum EditingReplies: 2Last Post: 18th Jan 2008, 23:01
