hi, I'm having trouble to capture AVI file under MMC7.x with the DIVX4.x codec because the configuration tab is greyed. The system will use the last known configuration (i.e. if you open VDUB it will use whatever settings you will set there). Also in the windows "sound and multimedia" panel is not possible to select the codec settings and it only gives you the version details. Am I the only one to have this problem. Is there a fix?
Ciao
Andrea
Results 1 to 1 of 1
Confusion about DivX-Encoding settings
By foxhunter in forum Newbie / General discussionsReplies: 37Last Post: 23rd Jul 2009, 12:26 -
DVD to DivX - settings for better quality
By CodeMaster2008 in forum DVD RippingReplies: 11Last Post: 14th Jul 2009, 04:20 -
Recommended settings for dvd to divx ?
By jimcgr in forum DVD RippingReplies: 6Last Post: 11th Feb 2008, 08:25 -
Dr. DivX subtitle settings
By drstupid in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:13 -
Configuration settings Help for Exsate DV Capture
By Logan69 in forum Capturing and VCRReplies: 1Last Post: 25th Oct 2007, 10:57
