I have encountered crashing in demuxing dual audio videos in VirtualDubMod . Are there other ways to demultiplex? other programs that can do that?
Results 1 to 9 of 9
i think he means for avi files -- but he doesnt really say ..
imuxer is one of the best of mpeg files .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Well with VirtualDubMod it could be ogm, mkv or avi. AVIMuxGUI works quite well and can demux numerous audio and subtitle formats. Also there is mplayer/mencoder or ffmpeg.
Also graphedit. -
umm...the one i am demultiplexing is a dual audio anime (ogm) with subtitles. specifically Gundam G. i also need to demux the subtitles. what program do you recommend?
Thanks alot for replying -
is there a gui version of ogmdemuxer? my command prompt in my windows xp doesn't work
Not that I know of. The command line version is cross platform though, so you could run it under linux.
Try run-->cmd.
Demuxing DL problem
By calanda in forum Authoring (DVD)Replies: 9Last Post: 15th Feb 2010, 23:52 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Demuxing
By ckurowsk in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2008, 17:04 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05 -
what to do after demuxing?
By azizbhimani in forum SubtitleReplies: 2Last Post: 24th Feb 2008, 21:39
