Hello,
after changing from beta8 to RC2. The encoding process won't do an mp2 to ac3 audio conversion of my PAL SVCDs. In the registry there is ac3 enabled. But the log-file tells only mp2 to mp2 encoding.
I also tried the other options, to check if there is a checkbox failure, but it wasn't.
I'm not doing any PAL to NTSC conversion because of living in Germany.
Is ac3 encoding only working on NTSC assets or PAL to NTSC conversion assets ?
In beta8 everything was fine. RC1 wasn't tested by me.
I hope you can fix it in the final version or maybe in RC3, because I'm only working with PAL assets and I've paid for the program.
Thanks for an answer.
Bye
GULLY21![]()
This works for me....
Can you upload the file in question and your log. Can you save the project too and send me the s2d file so i can see the settings?
ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676/AC3SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
So it's done. My source file and my project plus log file are on your ftp.
Maybe the problem is that the source has 48kHz ?
Thanks for analyzing.
GULLY21
Yes that is the reason. Audio encoding is skipped if:Originally Posted by GULLY21
asset is ac3 audio
asset has 48khz audio
user chooses "skip"
This clearly is not ideal. I will make it so that it is skip if user chooses "skip" only.
Thoughts?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hello,
thanks for this answer.
Is it difficult to implement mpa with 48kHz to AC3 encoding ?
Or do you have a tip for me to transform the source first ?
Thanks a lot.
Bye
GULLY21 -
Like i say i will change the skipping logic. Email me for a new build.
mkvtoolnix no longer working for me
By pooksahib in forum Video ConversionReplies: 6Last Post: 13th Jun 2011, 09:14 -
Virtual Clonedrive no longer working
By Silver Fox in forum Software PlayingReplies: 0Last Post: 23rd Mar 2010, 12:26 -
iDVD / Toast Compression No Longer Working?
By toxicquack in forum MacReplies: 3Last Post: 26th Jul 2009, 12:57 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
ac3filter - back speakers no longer working for Prologic output
By pglenn in forum AudioReplies: 0Last Post: 7th Nov 2007, 00:09
