Hi
I would like to know what should be the best configuration of CCE or TMPGEnc, although I use CCE, to convert mpeg1 files to mpeg compliant DVD.
I have a lot of mpeg1 files and their resolution is 352x288 more or less, so what should be the best settings for converting to mpeg2 and achieve the best quality?
Thankx
..thoughts arrive like butterflies..
The best setting is not to convert at all! The resolution you quote is already DVD compliant for PAL. If the framrate of those video is 25fps and the bitrate less than 1800 kbps the video is already DVD compliant. The audio needs to be at 48khz sample rate though, so that may need to be converted. Some authoring apps such as DVDLab and Tmpgenc DVD Author will do that for you when you import the mpegs.Originally Posted by Jonas_VedderThere are 10 kinds of people in this world. Those that understand binary...
MPEG1 custom GOP settings
By sipposa in forum Video ConversionReplies: 8Last Post: 11th Jul 2011, 20:23 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 10:17 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08
