yep, output to hard disk folders (or alternatively, you could output to ISO then mount it with Daemon Tools if you wnated to), then open WinDVD, then look for "Open files from hard drive" or equivalent (I'm PowerDVD-oriented also, but it still should be able to do it). The key is to be able to load the VIDEO_TS.IFO file, and this will play exactly the same as if you had put a DVD into your settop DVD Player. Another alternative to WinDVD or PowerDVD is IFOEdit, BTW. I have used it's "DVD Play" feature many a time for testing various things.
If in doubt, Google it.
What is the best way to putt all my DVD to my Hard Disk?
By DVDhook in forum DVD RippingReplies: 4Last Post: 22nd Apr 2009, 05:00 -
Backing up Panasonic DMR-EH60 hard drive contents
By Jonesy127 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Mar 2009, 11:42 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
DVD to Hard Disk Recording
By jaicoa in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2008, 14:22 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48
