Dear Group: A couple of settings I would like help with are as follows. I want to take my AVI files & make them into DVD's. Now I understand the AVI files of course are recorded interlaced. In the deinterlacing tab do I leave it as "No deinterlacing" and if not which choice should I select? In addition my AVI files are from a DBS unit from Hi Definition that has been downconverted supposedly to 480i; however when I did some test recordings in MPEG2 leaving it as interlaced it had jagged edges as though I had changed the material from progressive to interlaced. Sure enough when I made a second test MPEG2 recording I selected progressive & the recording came out perfect; furthermore when I load my AVI file in AVI2DVD it says 29.998, so it is still being sent via the s-video cable in progressive. Well to get to my question do I want to make sure and select anamorphic in the aspcet ratio tab? And my last question is how should I record the audio when I am capturing for AVI I have been using 48.000KHZ 16Bit Stereo, but BBMPEG won't accept that, so should I allow AVI2DVD to re-convert the audio or change my audio settings on capture? If any one knows or has heard of any future capture cards that will allow for component, DVI/HDMI input please let me know.
Thanks In Advance,
William Forster
Hi ima2hd,
First thing - Please use paragraph breaks as reading one bigh chunk of text is difficult, and may put people off answering.
Q: What tool are you using to encode AVI to MPEG? I can't see any (clearly) mentioned...
In general, don't deinterlace if the end product is going to be watched on TV.
DVD audio is 48,000Hz 16-bit - See specs for DVD under "What Is... DVD" (top left of page).
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by ima2hdThere are 10 kinds of people in this world. Those that understand binary...
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
