  1. i backed up a copy of Hero onto Sony DVD+R's with my NEC ND-3500AG using DVD Shrink 3.2 to compress it then i tried both Nero 6 and then DVD decryptor but both come up with the same error messgae when put into either of my drives: "This file does not have a program associated with it for performing this action. Create an association in the Folder Options control panel." I can play it if I open WinDVD first but the DVD will not play on my other DVD players but I think it is related to the error message. ANybody know what it means or how to fix it?
    You are in breach of the forum rules and are being issued with a formal warning. Please don't cross post, one topic is enough.
    / Moderator Baldrick
    Apr 2004
    Miskatonic U
    What file are you clicking on to launch the DVD ? I don't quite understand what you are trying to do.
    Read my blog here.
  3. this error comes up both when i first put the dvd into my pc or when i try to click on the drive in My Computer
    Jul 2002
    Up in yo' bitch.
    If this message is coming up after you insert the DVD, your autoplay isn't set up. You need to set your autoplay options so that when a DVD video is inserted, WinDVD plays. This can actually get a bit annoying if you are backing up several dvds and have to close WinDVD everytime you insert a DVD video.
  5. Member blinky88's Avatar
    Mar 2004
    Australia
    You could try burning with Shrink to an ISO image and then burn with Decrypter. When you do this it will overcome the problems you now having.
  6. i have tried doing this with the iso once and it didnt work
