Help!
I have a bunch of footage shot in front of a bluescreen, and I can't for the life of me figure out how to set the blue as an alpha channel / transparent layer in Vegas.
In something like Adobe Premiere, it is relatively straightforward (just bring up the transparency window, set it to recognize the alpha channel as blue and adjust the parameters... the blue dissapears and the background image shows through. easy)
But I've been struggling for days to get Vegas to do this... I've searched all the online help places and Vegas tutorials with no luck!
Help?
Ryan
in Vegas 4, it's pretty easy - add your primary footage (what was shot in front of the screen) to a video track. select the track FX (little green box with two circles coming out of it) and pick "Chroma Keyer" from the list of effects.
once the Chroma Keyer opens, you can manually set the color, or you can click the little eyedropper icon at the lower left, and select your background color using that.
now add another video track and drag your background onto it. it should show up.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
all you need to do is go to the FX tab and drag 'chromakey' over to your clip and drop it on top. A window will pop up to let you make the adjustments you need.
if you have shadows on your backdrop, you can add multiple chromakeys also to take care of those
Another Sony Vegas Pro question.
By ingeborgdot in forum EditingReplies: 17Last Post: 9th Dec 2009, 12:42 -
Sony Vegas 8 Pro question
By ingeborgdot in forum EditingReplies: 2Last Post: 30th Nov 2009, 16:59 -
Vegas 8 pro question
By schematic2 in forum EditingReplies: 1Last Post: 14th Oct 2008, 21:44 -
Vegas render question
By wingfan in forum EditingReplies: 2Last Post: 29th Sep 2008, 19:10 -
Sony Vegas Question
By ChristianPaprika in forum Newbie / General discussionsReplies: 14Last Post: 29th Aug 2007, 22:46
