Results 1 to 16 of 16
  1. Thanks
  2. Thanks
  3. What authoring app are you going to use?
    Why mux it in tmpgenc?
    Have you definietly got the ac3 plugin?
    Cheers, Jim
    My DVDLab Guides
  4. I will Most likely use Ulead Workshop , I muxed it to make sure it plays right.
    My wallet says Yes I have the AC3 Plugin.
    canada
    Mux it with bbmpeg as dvd,does a better job with ac3 audio and m2v(mpv).
  6. Thanks
    Dec 2004
    Australia
    The warning is about hardware players. If the bitrate is too higher for too long then you may get a buffer underflow.
  8. Thanks
  9. Thanks
  10. Bump
  11. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    AC3 is not valid as audio in an mpeg, only MP2. I suspect that is the cause of the error message. You should be able to author your audio and video together as seperate streams, depends on your authoring program. Ulead isn't the best and may not have that capability.
  12. Thanks
  13. Originally Posted by ZippyP.
    Cheers, Jim
    My DVDLab Guides
  14. Originally Posted by reboot
    Yeah I didnt understand it to.
  15. Video Restorer lordsmurf's Avatar
    AC3 is often corrupt on Panasonic units.
    What is this one?
  16. I converted the Audio to AC3 it was mpg Audio from the recorder. Liteon.
