  1. Hey,
    I just created / produced my first helicopter music DVD. It came out pretty good. However, after burning a bunch, I ran into this whole issue of DVD -R and DVD + R formats. Why is it that virtually all DVD's I have ever purchased (600 + and counting) work on all of my DVD players (4 and counting) and there's no format issue.
    What do I need to do next time to have my DVD work in all players?
    thanks,
    matthew
  2. Keep doing what you've been doing?
    edit: I misunderstood you, I thought you'd meant you've already burned 600 without any issues...
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Have it professionally done, purchased DVD's are stamped not burned. That's the only 100% solution.
  4. any suggestions on who stamps them good/cheap?
  5. If you are really concerned about compatibility it is massivly cheaper to buy equipment that will play either - or + than to try to match your burning to outdated equipment. If you are burning for others, burn both formats and bitset the +R. At 40 cents per disc it is still cheaper than pressing.
    Still a few bugs in the system...
  6. thanks chas, the main issue isn't me.... it's giving the dvd to customers, friends, and relatives. It just needs to work for them (non-techie types).
    I did burn both dvd -r and +r versions (used different labels to keep them straight). It's just a hassle to have someone try one, then send them the other.
    What do you mean by "burn both and bitset the +R?"
    40 cents a disk is fine if it will solve this problem...
    Nov 2003
    Ontario, Canada
    He means this.
    If your DVD burner allows "bit-setting" or "book-type setting", that's the way to go. Use +R blanks and set the book type to "DVD-ROM".
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You could always ask them what typr DVD player they have if it's just for a single customer, look the player up to the left to see what's compatible. Include a note as to why it might not work.
