I have a backed up dvd, and its the only one I have. Its not a movie or anything, its compiled videos of random things... well, I need a copy of it. I've tried everything to copy it. Nero, Dvd decryptor, smart ripper.. they all fail and give read errors.. the disk plays fine, and there aren't any scratches on the dvd. I don't understand? any thoughts? Thx
only_emo_kidGuest
only_emo_kidGuest
Okay, I'll try that now and see the outcome... I may have tried it before because i have it installed on my computer but i'm not sure.. Thanks
only_emo_kidGuest
follow up... now i can't even get the dvd to read in my drives.... !! %@%@$^#*%
If you haven't tried this already, try reading it in the drive that burned it (ie: your burner). I've had media that reads with errors but pop it back into the burner rather than DVD-ROM and the burner reads it OK. Get it off that media QUICK.
Ya, it should work fine with nero>copy disc, gots to be da media mon.
COPIED OVER 600 DVDS SO FAR -
I just had a similar problem as yours. Try ripping the disc with VOB BLANKER. I had a disc that had complied footage of camcorder tapes converted via a liteon dvd recorder. My friend had not finalized the disc but when he did it wouldn't playback on any dvd player. I couldn't rip the disc with decrypter or dvdshrink to even read the disc. I used VOB BLANKER to rip which was successful then used DVD SHRINK with no compression and then burned with NERO BURN.
If you're going to use NERO DISC COPY make sure your read speed is double of your dvd burner speed.
DVD player's copy protection won't even let me rip home movies.
By Brian. in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Mar 2011, 15:12 -
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
DVD is only available from Australia (PAL)- can I rip it and make a copy?
By stoker in forum MacReplies: 6Last Post: 22nd Sep 2010, 23:11 -
How do I copy/rip a DVD-RW created on a Sony hxd560 recorder?
By BrianLy in forum DVD RippingReplies: 5Last Post: 3rd Feb 2008, 07:18
