Hi All,
I need to clean up my codecs in a big way. Performance is choppy in playback, there are sych issues in encoding(canopus, mainconcept and tmpeg), vegas editor, there is a problem vegas 5 even importing sound that is embedded in an avi. If anyone knows of any other thing that might be causing these systemic problems let me know, however I am thinking its the codecs I have loaded. It has been suggested that codec sniper might help but alas when I run it it gives me this error before it starts up.
zugriffsverletzung bei Adresse 004047DE in modul 'codec_sniper.exe'. Lesen von Adresse FFFFFFF7
Anyone know of another way of cleaning codecs up or perhaps getting sniper to work?
You could try Filmerit
Paul Glagla
http://paul.glagla.free.fr/index_en.htm -
very nice app -- thanksOriginally Posted by Paul Glagla"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Audio is embeded avi
0x0055(MP3) ID'd as MPEG-1 Layer 3
and divx 5.0 in some cases.
But really nothing seems to be working properly at all, there seems to be too many problems that it can't be just vegas, I think vegas seems to be reading codecs wrong. At least that is the straw I am grasping at. Here is what the program mentioned above said;
366 records of directshow filters
0 records are erroneous
That seems like a lot of filters?? -
yes -- that is to many ....
i have 179 and a lot of custom ones in that"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
VHS Cleanup, What can i do?
By Asesinato in forum RestorationReplies: 115Last Post: 5th Apr 2012, 13:31 -
help with dvd cleanup
By jszorady in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2011, 13:32 -
Codec Cleanup
By jieve in forum Software PlayingReplies: 2Last Post: 14th Aug 2009, 17:18 -
Disk Cleanup
By chithanh119 in forum ComputerReplies: 2Last Post: 16th Oct 2008, 14:15 -
cleanup on old vhs tapes
By kesuki in forum Video ConversionReplies: 1Last Post: 22nd Jun 2008, 17:33
