I have an *.avi file that has VBR MP3 audio and I need it to be CRB so I decompressed the audio to an uncompressed WAV file and then encoded it to a CBR MP3 file using Lame.
My question is this, what program will take my new MP3 file and replace the old one in the *.avi file?
Thanks,
John
Virtualdubmod. Open your AVI. Go to streams > stream list, and select the existing audio stream the click the disable button. Then click the Add button and select your new audio file. Right-click on this new audio file and confirm that it is set to Direct Stream Copy. OK your way out, then go to Video > Direct Stream Copy, Then go to File > Save as ... and save out to a new AVI file.
If in doubt, Google it. -
Thankyou, it worked like a charm. I didn't even know VDubMod existed, I only knew of VDub.
Thanks again,
John
No sound when replacing audio
By konu in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2011, 20:10 -
help replacing audio on DVD
By fullbohr in forum AudioReplies: 3Last Post: 12th Nov 2009, 21:34 -
Replacing audio in MKV file without re-encoding?
By 3560freak in forum Video ConversionReplies: 4Last Post: 2nd Mar 2009, 23:23 -
replacing audio on a dvd
By phillbrett68 in forum Authoring (DVD)Replies: 2Last Post: 7th Dec 2008, 02:00 -
Replacing MPEG audio.
By dfisher052 in forum AudioReplies: 3Last Post: 16th Oct 2007, 14:14
