Has anyone else noticed that the audio sync is off when joining two avi files? Specific example, repeated multiple times on multiple files:
I have an avi file of a TV show. There is roughly one minute of the opening scene, then the opening credits, then the rest of the episode. If I use ffmpegX to split it into three pieces, and then join the first and last (the opening scene with the rest of the episode), the rest of the episode's audio will be out of sync with the video. Looking through previous posts I saw an example of different framerates resulting in audio sync problems, but since both parts are from the same original file this should not be an issue. Any thoughts? 0.0.9s on Mac OS X 10.3.4 with a G4.
Dave
The AVI format is a poor format in handling video and audio sync. Right now, splitting and then joining has issues (the problem is in the join step). I will try to use a different join method to overcome these issues. In the meantime I would suggest to use Quicktime Player to do editing.
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 21:18 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 14:55 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 14:32 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29
