I'm having trouble fitting my SVCD encode (DVD source) to 2 x 80min CD-Rs. I did a 3-pass VBR using CCE v2.70.01.05 with the following settings:
Bitrate - Avg-2082, Min-0, Max-2524 (Values were attained from FitCD v1.2.4 by putting in 95min video @ 23.976fps, MP2 224, and 2 x 80min CD.)
After the encode, I ended up with a .mpv with a size of 1.40Gig (1,476,348KB).
The .mp2 (which was from the .ac3 from DVD2AVI) was done in BeSweet w/ setting of 224. The final size of the .mp2 was 154MB (158,653KB).
(Ran pulldown.exe)
I multiplexed the two together with bbmpeg using 797 for max CD length and ended up w/ 3 .mpg's. (3 CDs) The 3rd CD is only 41MB.
So, my main question is have I done something incorrect? Shouldn't I have gotten just 2 CD's based off my bitrate I got from FitCD? .. And the fact that I did a 3-pass VBR so the file size would be even more close to the size of 2 CDs?
Please help me out as I've done this twice now, only the first time I used the Min. AVG that FitCD gave me (instead of "0") and both ended up the same size (within a meg or two).
Thanks.
Thanks for the reply, but I'm wondering what I did wrong in the method I used. I'll look into it though.
Originally Posted by greedy
The number of test encodes and the size of the test clips are determined by you.
Give it a try.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27
