I am having difficulty encoding a divx3 file to DVD with CCE. It is not encoding at all when I use DIKO and when I try CCE by itself it is giving me an error about finding the codec. I have DIVX 5.02 installed. I assume that would suffice for the current project. Is it not backwards compatible so to speak? Do I need to install the 3.11 codec for CCE to work or am totally off base and something else need be done?
Divx 5.02 should accept the DIV3 fourCC fine. What happens if you open the file via say VirtualDub?
If it opens in VirtualDub, then you can frameserve it to CCE. I do this often. It also allows you to resize, filter and adjust on the way through.
Read my blog here.
From what I remember though the divx3.11alpha decoder was somewhat buggy. The VFW decoder I think outputted RGB24 always.
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 18:24 -
DivX3 Problems
By Startropic1 in forum Video ConversionReplies: 4Last Post: 13th Jul 2010, 06:58 -
Is it possible to use xVid to decode Divx3?
By cheerful in forum Software PlayingReplies: 0Last Post: 10th Feb 2010, 12:35 -
Biostek XS-600 HD doesn't like divx3 what should i do?
By vivificus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Jan 2008, 09:05 -
DivX3 to DivX6???
By npresto in forum Video ConversionReplies: 3Last Post: 28th May 2007, 18:49
