Just wondering, what would be the best way to compress an AVI produced by Fraps 2.5.1? I want to keep the quality the same, at least to the eye, and leave the resolution the same also. I've tried using VirtualDub along with the DivX codec, but that always produces a small file that looks like shit at the highest settings. I've used Dr. Divx, which also produces shit. XviD works alright, but I'm affraid that I'm not using that to its fullest ability, as a 1024 x 768 1 minute long video turns out to be 300 MB. I don't see how movies can be compressed using DivX, retaining a majority of their quality, and end up being only 700 or so MB.Anyways, no more ranting, thanks for any advice.
Ive used windows movie maker to compress the fraps file, so I could email it or send it through MSN. It was just a silly game movie (what else can you use fraps for?).
Just import it into Windows MM, and then dont bother editing (if you dont want to) and choose "save as movie file".
You then get several choices for saving formats, but you can just choose save for "my computer". After hitting next, when you get to a checked off "Best quality...." button, click more choices below it and the list will open up.
Then pick whats best for you. It has all the file sizes with the choice you pick too.
Need To Compress Large AVI For Youtube
By r04dw4rri0r in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2010, 11:18 -
How to compress DV avi
By marti252 in forum Video ConversionReplies: 12Last Post: 7th Dec 2009, 03:12 -
Compress 50GB avi to one DVD
By pauldaymond in forum Video ConversionReplies: 5Last Post: 27th Mar 2009, 11:53 -
How to compress FRAPS capture for YouTube upload?
By ReiKo90 in forum Newbie / General discussionsReplies: 10Last Post: 4th Feb 2008, 10:12 -
Help with subtitles, compress avi
By hello123 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2007, 10:41
